Countdown To Christmas!
WH854
Spare Parts 8 Speed
WH854
Sat. I went to see a fellow about an 8 speed transmission he was selling. Ibought it for $40.00. I think it was worth it! Iwill be using it for spare parts what is left of it anyway.Here are some pictures!!!
PUllys are off and the hub in this picture!
Had to sacrifice the drive pully it was a bit stubborn!!
I will need the left side of case if I would want to ever use it.
I wonder some time how people can break stuff, especially where the case is broken in the picture. :thumbs: The man I bought this from said he bought it from another man. That axle was flopping up and down in the case
Chas :)
WH854
Howdy fellers and gals!!!
I am starting to repair this transmission, I have a new used case for it!!
So I cleaned up around the drain plug, cleaned the dirt and grease out of the plug,so I could get the allen wrench to fit real good. Here is a picture!!
With the plug out!!
Picture of plug and allen wrench with plug removed!!
Picture showing wrench in plug on transmission!!
I will show more pictures later as I go a long :thumbs:
Chas
racinfool40
Great Idea to grap up these tranny's!!! I'm buying or Acquiring all that I find.. Up to 5 8spds and 2 4spds as of now. Almost all the gears and bearings will inter change depending on the model of tranny!! So any extra parts others may need down the road!! :thumbs:
WH854
Well Guys and Gals I did more work on the transmission today!! Cleaned the axles and pully shafts with sanding cloth, took the case apart. Here is what it looks like!!
This next picture is the case all this stuff is going into :wh:
Hopefully with no problems :thumbs: If I can follow the manual!!
Chas
Lane Ranger
Looks like you are well on your way with a good parts transmission!
Good luck on the rebuild. Just take you time and it will go well.
:thumbs:
WH854
Howdy Guys and Gals!! Another day has passed I did some more work on the transmission today. Took all the insides out as per the manual, every thing seem to be ok, except the hi-low shift fork broken :thumbs: I didn't take any pictures because my hands kept getting oil all over things :D I will try when I put it back together. I have to buy some seals and that shift fork (Hi-Low) maybe some bearings, I have some bearings in my ditty bag(you navy guys should know what a ditty bag is) :wh:
Chas
WH854
I called in my parts list for this transmission
ORDER LIST
1- 323-10-SCREW-HH -AMT( 5)
2- 32153-2 LOCK NUT AMT(6)
3- 1239 SETSCREW AMT(1)
4- 3217-5 NUT-HEX AMT(1)
5- 100441 SEAL OIL AMT(1)
6 - 100442 SEAL OIL AMT(1)
7 - 100443 SEAL OIL AMT(2)
8- 3912 GASKET TRANSMISSION AMT(1)
9- 3577 COVER DUST AMT(1)
10- 9547 WASHER-THRUST AM(1)
11- 3517 BALL-DETENT AMT(4)
12- 106030 SPRING-SHIFT LOCK AMT(2)
13- 933184 PIN-SPIROL AMT(2)
14- 323-15 SCREW-HH AMT(1)
15- 116636-03 HI-LOW SHIFT FORK AMT(1)
All of this came to 98 dollers plus tax
Should be here next Monday :thumbs:
Chas
WH854
Howdy again Guys and Gals! I decided since it a nice day I would paint the new transmission case. Here is a couple of pictures of it.
I also removed the needle bearings out of the bad side of the old case.
This next picture shows the bearings still in the case.
I would like to pull the roller bearing to if I can get the right puller :thumbs:
If my parts come this Monday I will be all set to put it back together. :wh:
Chas
WH854
Howdy Guys and Gals My parts came in today all of them :thumbs:
So the first thing I double check every thing, To make sure. :D
Then I proceded to put the spring and ball plus detent bolt together,Gotcha you rascal Here
Next 2 Pictures are of the old one :D
It only took 4 trys with the wifes help :D:wh:
Chas
WH854
Did some more work on the transmission!! Here are some pictures!!
The first picture is the low-hi fork installed
The next one ( I think is 2nd and High rail installed)
The next two is with booth rails installed
The next picture is with more gears installed
Sorry about the pictures my camera tells me I am too Shakey :thumbs:
Chas
can whlvr
looking good,its nice to have a spare tranny ready if somthing goes wrong
WH854
Howdy Guys and Gals!! I got this project almost finished :D Suprise,Suprise :wh: Every thing went along with out a hitch :D
Here are the pictures hope i can get them in order :D
I would like to thank the fellow RS members for the tutorials(stevasaurus and dgks6) most likely why I came out of this project with out any thing going wrong :thumbs::wh::D
Chas
WH854
This transmission I put  in my C-165 Auto, also installed a manual lift and clutch peddle and parts for the brake :thumbs:
I think I named everything it works anyway. I have a C-165 8 speed instead of Auto :scratchead:
Chas
stevasaurus
Chas...always gets me how bad those spare transmissions can look on the outside...and there ends up being nothing wrong inside. :)
Very nice job and pictures. :)
WH854
:thanks: Steve  Time and patience! :thumbs:
Chas
