312horse
tiller
312horse
I need some pictures of the pulley placement showing the proper bolt holes below the pto on a 312-8 or a 416-8 i have the tiller which is mounted on a hydro drive but i plan on moving the tiller over to either my 312-8 or my 416-8 i could receive pictures at danda01@charter.net thanks to who ever answers DAVE
HankB
Does this help?
I'm not positive it is correct.
:thumbs:
-hank
312horse
I thank you for the picture , it looks like you have to remove the tach matic latch? :thumbs:
MaineDad
You keep the mid attachment latch because that is how you attach the tension pulley setup. I do not have a pic now, but could find one later.
312horse
Thanks , I need all the help i can get without having the manual , the pictures really help .I have plenty of time between now and spring to get the info together i certainly appreciate the help from you folks on here Dave
312horse
Great , these pictures really help , i think now the problem i have , the front pulleys are bolted to the frame instead of being latched in tach matic because the tiller is mounted on a tractor before tach matic came along , the tractor is a hydro drive also and don,t seem to have much holdback potential when trying to till with it .Thats why i think i will put the tiller over on one of my 312-8s or my 416 -8
HankB
That's right. The older style bolts to the frame. You (the OP) could try modifying the one you have or trading with someone who has a newer style and needs the older one. If you want to try the modification, I'd be glad to take detailed pictures and measurements of mine to get you off to a good start.
I till with a hydro and if I take a big bite, it can push the tractor a bit. I've heard that tilling with a manual trans works better and given the choice of tractors you have, I'd choose the 416-8. Plenty of power for the tiller and steady speeds with the manual.
-hank
312horse
Well I certainly thank you Hank, for the offer to show the mods , and i certainly could use the info .And yes i think the 416would be the best choice even tho it only takes an hour or so to do my tilling and i hate to tie that tractor up untill time to use it in the fall again . thats why i have four tractors , i have a plow , chains and weights, on a 312-8 (with electric lift by the way ) then i have a 48 in deck on the 416-8 , then i have a 36 rd mower on the other 312-8 .I just bought this tractor the other day, that has the tiller on it and wheel weights , but it seems awful light on the front end and it don,t take much to pop a wheely if i do leave it as a tiller tractor i will try and add some weight out in front doggone here i go getting long winded Dave in N. Michigan
312horse
Hank , I got to looking the pulley thing over and it turns out this tractor has a sort of tach matic latch on it, it don,t look much like the ones one the newer tractors but it turns out the pulley setup has a bar that goes clear across under the frame , so i would say it will snap right on anyone of the newer tractors , so by golly i think i,ll be all set now , thanks again for the help Dave
