clarnp49 0 #1 Posted April 22, 2008 Ok, So I bought new spindles for my deck and I also bought a new center pulley. The problem is the spindles don't have key's in them and the center pulley is almost a 1/2" bigger and keyed. Any suggestions for making this work? I still have one more spindle to buy so if I need to buy a different spindle please let me know. The center pulley is rounded obviously. Thanks in advance. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #2 Posted April 22, 2008 Do your original spindle shafts have a flat milled on each side? (also know as a "Double-D" ) (and your original pulleys were probably "cast iron".) Share this post Link to post Share on other sites
clarnp49 0 #3 Posted April 22, 2008 That is correct. The problem is I needed new spindles because the old ones were worn out, so I went to JacksSmallEngine.com and ordered the spindle which is round so I was just going to get a new set of blades as well. Is there an adapter or bigger spindle shaft I should be looking at? Share this post Link to post Share on other sites
glenn27 71 #4 Posted April 22, 2008 Do your original spindle shafts have a flat milled on each side? (also know as a "Double-D" ) (and your original pulleys were probably "cast iron".) Double-D's are great--on some applications!! {Sorry--couldn't halp that one....} Share this post Link to post Share on other sites
kj4kicks 151 #5 Posted April 22, 2008 Yeah, but they are usually high maintenence ! Ok to keep it on topic, you'll probably need all new pulleys to match the new spindles. Share this post Link to post Share on other sites
clarnp49 0 #6 Posted April 22, 2008 Ok to keep it on topic, you'll probably need all new pulleys to match the new spindles. That's what I thought and then it occured to me. Ask the gentleman I bought the pulley from, he has the right one and I am all set. It's a 5/8" shaft instead of the old 3/4". Thanks for the help Guys! Share this post Link to post Share on other sites
