dhuberinc 1 #1 Posted October 14, 2010 Greetings! Ok, thanks to the good people on this site I fixed the recoil on the H55B on my recently acquired 1960 Suburban and want to move on to the electric starter which wasn't hooked up. It came with a few loose cable chunks and a solenoid but no key or starter switch. I see a couple wiring diagrams in other posts regarding other starters but want to be clear before proceeding. My questions are: what kind of switch will work and fit in the hole on the dash, where is the preferred placement of the battery and solenoid, and is there a wiring diagram available specifically for this starter? Thanks a million. Share this post Link to post Share on other sites
dhuberinc 1 #2 Posted October 19, 2010 I'm not getting very far with this. I have a new solenoid, the three prong type. I know one side goes to the starter & one side goes to the + side of the battery. I know you ground the battery somewhere on the engine block. I found an original split key ignition switch at a swap meet with a red wire (connected to post S) & black wire (connected at post M) and it has a ground post coming from the switch body so I assume it gets that from the mounting hole. I'm stuck at this point because I don't want to burn anything out. I see this electrical thing on the front of the motor & know it interacts with the electrics somehow. Can anyone out there make clear where I go from here? Share this post Link to post Share on other sites
Kelly 1,029 #3 Posted October 25, 2010 I don't want to steer you in the wrong direction, you have a tractor that is not very common, so not many will have the answer, but someone will see this and help you out. Share this post Link to post Share on other sites
