Kelly 1,029 #2 Posted April 19, 2008 Hard to see the pic's post them the next size bigger or two bigger I use the mesage board settings but anyway nice weights Share this post Link to post Share on other sites
Curmudgeon 28 #3 Posted April 20, 2008 Sweet looking weights!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
Dave 0 #4 Posted April 21, 2008 I can't afford weights like that but would the front end of a C81 hold up a really heavy bumper? I have some angle iron and an old 4 inch box beam I could weld together. Share this post Link to post Share on other sites
jrfan882008 2 #5 Posted April 22, 2008 weights dont cost alot takes more time heatin lead for the pour used a old rim as a mold Share this post Link to post Share on other sites
KyBlue 655 #6 Posted April 22, 2008 Those are pretty nice. Way to Go! Share this post Link to post Share on other sites
jrfan882008 2 #7 Posted April 22, 2008 thanks they weigh 56lbs. back each and front are 22lbs. each cant buy weight like this lol Share this post Link to post Share on other sites
Sparky-(Admin) 21,300 #8 Posted April 22, 2008 I can't afford weights like that but would the front end of a C81 hold up a really heavy bumper? I have some angle iron and an old 4 inch box beam I could weld together. I think the front end will take the weighted bumper but it might steer hard at slow speeds( like we go fast right ). Front wheel weights would not affect steering and you would get the same results. Mike.............. Share this post Link to post Share on other sites
wse100 0 #9 Posted April 22, 2008 jrfan882008, Did you pour the lead then drill where the lugs went, or did you build in holes? Also what prep did you do to the old rim to make it a "mold". Share this post Link to post Share on other sites
Dave 0 #10 Posted April 22, 2008 I think the front end will take the weighted bumper but it might steer hard at slow speeds( like we go fast right ). Front wheel weights would not affect steering and you would get the same results. Mike.............. That's my problem, no steering at low speeds or starting off. Sometimes the frond end comes up. If they're just lead, I can melt some and pour it into a mold of some kind. Share this post Link to post Share on other sites
jrfan882008 2 #11 Posted April 22, 2008 took a peice of metel put it in bottom of rim only holes in weight is the two carrage bolts holdin them in place Share this post Link to post Share on other sites
