fender62p 0 #1 Posted October 11, 2010 Hi, I partially disassembled my 418C, model 41-18KE01, initially to replace a hydro line. I was getting over my head, and never did get the line replaced (I just use it for plowing and can live with the leak). Anyway, while taking it apart, i noticed the trans belt was worn very bad, so i replaced it. My neighbor, who is more of a mechanic than i, suggested i remove battery till i was done, which i did. Tractor was in parts for a couple weeks till i got my belt and put it back together. But now it won't start. Lights come on, and guages on dash work, but the starter will not turn over. I double checked the PTO which prevents starting when engaged, and the seat "kill" switch. Any ideas what i did wrong? THanks, much, really appreciate your help - my wife is getting a big kick out my trying to be a mechanic - ted Share this post Link to post Share on other sites
Sparky-(Admin) 26,706 #2 Posted October 11, 2010 Does the brake pedal need to be pushed for starting? I had a 418 but cant remember if it needed to be pushed or not. Or maybe mine was bypassed ? Mike....... Share this post Link to post Share on other sites
WH nut 553 #3 Posted October 11, 2010 Make sure you didnt knock the wires loose on the Ign. switch when you were messing with the battery, also the clutch switch is a good guess also Share this post Link to post Share on other sites
fender62p 0 #4 Posted October 11, 2010 THanks Mike, You're correct - the 418C does need the brake depressed to start, but alas i had already tried that too. Rick, I'm hoping you're correct. I'll take a close look at the ignition. I didn't look too closely at that before, because ignition must be "on" for the lights to work, and they do. But a second look won't hurt - thanks, ted Share this post Link to post Share on other sites
wallfish 20,738 #5 Posted October 11, 2010 Sounds like one of the safety switches, recheck those. Make sure your battery cables and terminals are clean and tight too since you removed them from battery. I have a 418C also and every once in a while it will do nothing when I go to start it, just haven't got to it to find out why, bad ground maybe. Share this post Link to post Share on other sites
WH nut 553 #6 Posted October 11, 2010 And make sure the battery is hooked up right Share this post Link to post Share on other sites
