wallfish 17,397 #1 Posted October 4, 2010 These tranny pics are from a Share this post Link to post Share on other sites
wallfish 17,397 #2 Posted October 5, 2010 Answer to my own question After thinking about it and looking at the pics again, mabe a PO added this because the hub would keep slipping into the seal, causing it to leak. Share this post Link to post Share on other sites
kpinnc 13,491 #3 Posted October 5, 2010 You probably nailed the reason- you will probably find the hub has a groove worn into it where it was rubbing the case, which would allow it to "dig in" to the seal. The newer Eaton transmissions used a thick low-friction plastic washer to prevent the same thing from happening. Share this post Link to post Share on other sites
