REDNGREEN 0 #1 Posted October 3, 2010 I have noticed the last few times mowing that after warming up for 10 to 15 minutes that my c120 auto will not climb small inclines any more. I changed the filter and oil and at the beginning of this season. I would say that I have put probably 15 hours on it since then. Cant remember for sure what i put in, but I put in whatever the sticker on the side said to put in. I think it was 10w30 or 40. Anyway, the oil looks like new and is still full. Any suggestions? Thanks Share this post Link to post Share on other sites
pumper.atv 26 #2 Posted October 4, 2010 what kind of oil did you put in? Certain oils will foam when warm and cause lots of problems :) Share this post Link to post Share on other sites
REDNGREEN 0 #3 Posted October 4, 2010 I cant remember right now but it was whatever was recomended on the sticker on the belt guard. What kind of problems might I be lookin at? Pump rebuild kinda problems or could i get away with filter and oil change with whatever kind of oil you guys recomend? Share this post Link to post Share on other sites
pumper.atv 26 #4 Posted October 4, 2010 was it regular engine oil that you used? :USA: Share this post Link to post Share on other sites
REDNGREEN 0 #5 Posted October 4, 2010 Yes, I am pretty sure it was 10W40 but i will check tomorrow. This is starting to sound not so good. I thought it sounded odd to put motor oil in there but I asked a guy at the local small engine shop (Toro dealer) and he agreed with what the belt guard said. What do you recomend in the future and do you think I ruined my pump? Share this post Link to post Share on other sites
WH854 44 #6 Posted October 4, 2010 :wh: You can go to this site and put your model # in and put none in for serial# might help you some. For instance Model # 1-0485,1-0491,61-12KS01,61-12kS02,61-12KS03,61-12KS04. Hope this will help you some what https://lookup3.toro.com/request/request.cfm Chas :USA: Share this post Link to post Share on other sites
Shuboxlover 479 #7 Posted October 4, 2010 10w-30 should be correct, that's what i put in my 1976 c-160, and they should have the same hydro. have you checked/replaced your drive belt? it could be worn out, and when it gets hot it could stretch out a bit and cause your problem. good luck, keep us informed Share this post Link to post Share on other sites
REDNGREEN 0 #8 Posted October 4, 2010 I replaced the belt at the same time I did the filter and oil but the poor tractor has been sitting outside in the rain and elements ever since then. At the time I needed to get it running the toro dealer was closed and and the original belt was really bad shape so the only thing I could go by was visibly match it up with one at the "Thiesens" store. So I am not positive it is 100% perfect fit but it worked for a while. Now that I think about it, could this possibly be an issue related to the linkages and rust from the elements? Share this post Link to post Share on other sites
WH854 44 #9 Posted October 4, 2010 The P/N for your drive belt is 7478 it should be about 84" long 5/8"wide. Check your Transmission pully it may be slipping on the shaft. Chas Share this post Link to post Share on other sites
Shuboxlover 479 #10 Posted October 5, 2010 Now that I think about it, could this possibly be an issue related to the linkages and rust from the elements? You say that it's fine for a little bit, and then slows down.....If it was a rusty linkage, I would think it would do it ALL the time, and not just when it has been running for a bit. :) Share this post Link to post Share on other sites
REDNGREEN 0 #11 Posted October 5, 2010 Yeah, I figured it was a stretch on the rust being the problem. I know the hydro lever is a little stiffer than it used to be and was thinking that maybe it wasnt travelling forward far enough but you are right, that cant be the problem if it only does it when hot. I will hopefully get some time this weekend to check into it a little deeper. Thanks so much for all your help so far. Share this post Link to post Share on other sites
Shuboxlover 479 #12 Posted October 13, 2010 Did you figure anything out on this??? Share this post Link to post Share on other sites
