kimpaw
Front mount Haban SBM on a B-145
kimpaw
I saw one of these done and decided that it was a good idea and came up with this.It works well but I need to get the cutters dialed in better.
The mower is a 402 D off a cub cadet. Is that the same model# that was used on the WH Haban mowers? I have a miss matched set of shear fingers and cutter bar and can not get them aligned properly. The older mowers had single fingers and more offset than the newer replacement double fingers(part#6732). So I need a set of older single fingers. , Here is a link to a photo of what I have (part#6732)
and what I need part#3599A-(16 needed) and #3599B(1needed)
Thanks, Kimball
