ricky115 4 #1 Posted September 19, 2010 does anyone have a part# for the voltage regulator on a 12v starter generator system or can i use any regulator? would like to stay original. thanks rick Share this post Link to post Share on other sites
rmaynard 15,535 #2 Posted September 19, 2010 I believe that regulator is obsolete and not available from Toro or Kohler any longer, but you should be able to find a replacement for other tractors. Since it was a Delco, they should be available. I've been told that a Jacobsen 107927 will work. Don't know that to be a fact, but it's worth a little research. Search eBay with that number and I think there are a couple listed for about $44.00. Bob Share this post Link to post Share on other sites
ricky115 4 #3 Posted September 20, 2010 thanks for the info..i picked up a reulator at napa and made do for now, had the wiring diagram, worked like a charm...thanks again its up and running, now i have another problem it wont move...off to the tranny department...rick Share this post Link to post Share on other sites
