fender62p 0 #1 Posted September 12, 2010 Hi, I'm have a 418C tractor, model 41-18KE01. It has a hydraulic line which runs from the filter to the front of the pump (#109377). The leak is at the "filter" end and is accessible behind the rear tire. The other end of the line (pump) is inside the "hoodrest" box - If you're sitting on the tractor, it's straight down between you legs. I spent several hours taking pieces off the tractor to get access to the "pump" end of the line, but to no avail. Is there an easy way to get to "pump" end of the line to take it off? Can i "splice" or "mend" the "filter" end of the line since the "pump" end appears to be fine? And, Yes, i'm a newbie - Am I over my head, and should i take it to a pro? Thanks much, ted Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted September 12, 2010 :USA: Location? (someone on here might be close enough to help - or do it for you) Share this post Link to post Share on other sites
fender62p 0 #3 Posted September 12, 2010 I"m in Central PA, about 25 miles west of Harrisburg (Carlisle/Newville area - 17241) Share this post Link to post Share on other sites
fender62p 0 #4 Posted September 20, 2010 Hi again - Are there any sites which step you through dis-assembling the tractor to get to certain parts? Thanks. Share this post Link to post Share on other sites
Duff 206 #5 Posted September 21, 2010 Not really (others, please correct me if I'm wrong....). Most of us just go at it by intuition and, in time, experience. IPL's are handy to show how things go together. If there is a specific area or part you are trying to get to, post a question here and I'm sure someone will try to walk you through it. When I tore down my first 312-8 it was mostly by trial and error and the grace of God. When I got after the second one it was much easier, and as I prepare to rebuild #3 I've got notes and pictures, along with some memory, feeble though it may be at my age. If you can lay hands on one, a Shop Manual for your model is an invaluable aid! Best of luck! Duff :) Share this post Link to post Share on other sites
