catman81056 3 #1 Posted April 11, 2008 One of the tractors I got from the junk yard is a C-121/Electro 12 I need to know how to take the clutch off, can anyone fill me in? Thanks in advance. :thumbs: Share this post Link to post Share on other sites
refracman 167 #2 Posted April 11, 2008 Tim, once you remove the retaining bolt it "should slide off" but it could take a little help to get it off <_ Share this post Link to post Share on other sites
catman81056 3 #3 Posted April 11, 2008 There's a sticker on the outside of it that says something about threading a 5/8-11 into the clutch bore but the rest of the sticker is gone :thumbs: Share this post Link to post Share on other sites
Rollerman 290 #4 Posted April 12, 2008 Tim the inside bore of the clutch is threaded. Take the retaining bolt out & use a 5/8's 11 to thread back in...should push it right off the crank. Double check to see if it rreally is a 5/8" 11 & do not force it if it gets stuborn. Good luck :thumbs: Share this post Link to post Share on other sites
catman81056 3 #5 Posted April 12, 2008 Thanks Stephen :thumbs: Share this post Link to post Share on other sites
catman81056 3 #6 Posted April 12, 2008 Worked like a charm Thanks Again Share this post Link to post Share on other sites
