bmuone
Tail Lights
bmuone
Can I use the clearance lights (little cheapos from walmart) with one wire, on the rear of a 211-4? The headlights have a hot wire and a ground wire.
Save Old Iron
No problem,
the mounting screws need to hit a good ground connection - usually the metal pan is grounded to the chassis. If not, it is easy to create one.
bmuone
Thank you SOI. I THOUGHT it would work. You know how that thinking goes sometimes.
Kelly
I've used them from Walmart they are almost a prefect match, to the orig.
tgranthamfd
Got some good looking ones from Tractor Supply with 2 bulbs, basically the same as the wal-mart ones just an extra bulb, for about $4.99 ea. here is a link where you can see them.
http://www.wheelhorseforum.com/index.php?showtopic=17706
bmuone
Tks Kelly and Terry. I bought the Walmart lights while in Paris yesterday. Forgot about checking at TSC. Ck'd this morning and the ones I have will not require a new hole drilled like Kelly said. Those TSC lights may look more appropriate on my 417A when it needs new lights.
W9JAB
bmuone
They wouldn't know if I was coming or going! :)
rickv1957
W9JABs tail light would be great for night mowing! :) Rick
W9JAB
I put the back lamps on for dark October night when I'm using my leaf sweeper,
so I can see what is going into the basket.
