bmuone 15 #1 Posted August 17, 2010 Can I use the clearance lights (little cheapos from walmart) with one wire, on the rear of a 211-4? The headlights have a hot wire and a ground wire. Share this post Link to post Share on other sites
Save Old Iron 1,566 #2 Posted August 17, 2010 No problem, the mounting screws need to hit a good ground connection - usually the metal pan is grounded to the chassis. If not, it is easy to create one. Share this post Link to post Share on other sites
bmuone 15 #3 Posted August 17, 2010 Thank you SOI. I THOUGHT it would work. You know how that thinking goes sometimes. Share this post Link to post Share on other sites
Kelly 1,029 #4 Posted August 17, 2010 I've used them from Walmart they are almost a prefect match, to the orig. Share this post Link to post Share on other sites
tgranthamfd 29 #5 Posted August 18, 2010 Got some good looking ones from Tractor Supply with 2 bulbs, basically the same as the wal-mart ones just an extra bulb, for about $4.99 ea. here is a link where you can see them. http://www.wheelhorseforum.com/index.php?showtopic=17706 Share this post Link to post Share on other sites
bmuone 15 #6 Posted August 18, 2010 Tks Kelly and Terry. I bought the Walmart lights while in Paris yesterday. Forgot about checking at TSC. Ck'd this morning and the ones I have will not require a new hole drilled like Kelly said. Those TSC lights may look more appropriate on my 417A when it needs new lights. Share this post Link to post Share on other sites
bmuone 15 #8 Posted August 18, 2010 They wouldn't know if I was coming or going! :) Share this post Link to post Share on other sites
rickv1957 72 #9 Posted August 18, 2010 W9JABs tail light would be great for night mowing! Rick Share this post Link to post Share on other sites
W9JAB 156 #10 Posted August 18, 2010 I put the back lamps on for dark October night when I'm using my leaf sweeper, so I can see what is going into the basket. :) Share this post Link to post Share on other sites
