ba2988
314 hydro trans issue
ba2988
Was mowing yesterday and the tractor came to a sudden dead stop. After getting off and making sure that I hadn't run over anything and checking drive belt I started it back up and put it into reverse - went a few feet and stopped sudden again. I was able to limp back to the garage if going very slow. This morning went out and rechecked everything belts, motion control linkage, fluid level and everything looked ok. Started it up and was able to go about 10 feet before it stopped.
After that I couldn't even push the tractor more than 2 feet in either direction even if pushing very slow.
I'm thinking that its an issue with the trans and not the hydro pump. Any thoughts?
Took me all morning to get it back in the garage - had to come up with a unintended use for a front mower deck carrier -removed rear tires and put the carrier under the tractor, wheels toward the back and hooked into the mid tachamatic.
Tractor is a 93 - 314 with hydro and hydrolic lift. Lift still operates fine and there was no strange noises from the hydro pump when I was trying to move.
ba2988
Well I haven't had time to take this to the shop or look into it myself further. Assuming the worst, that its an issue with any of the main components to the hydro system (pump, transmission, transaxle) what are some potential donor tractors with rear ends that I could use for parts/components. I would guess any hydro 300, 400, or 500 - what other models can be used?
rustynut
someone should help this guy out
Jim_M
Check to make sure you haven't sheared a woodruff key between the axle and the hub.
buckrancher
I dunno Jim I think if he sheared off the shaft keys he would be able to
roll the tractor . :)
I believe
you can have hyd pressure for raiseing and lowering the deck and still
not move the tractor but this sounds more like something has came apart in the trans.
hopefully TT will chime in on this problem
TT
:) It very well could be one (or more) of the through-bolts in the differential assembly. (The more attempts made at trying to get it to move, the more damage could potentially occur - so.............
Pull the transaxle, split it, and have a look. Hopefully it won't cost more than the gaskets and a few new bolts and nuts for the differential.
Jim_M
You're right. I didn't think that one through.
ba2988
Thanks for the advice...haven't had time yet to open it up but I appreciate the suggestions. Hope to get to it in the next few weeks - am borrowing a Husqvarna and there really is no comparison to cut quality or power.
dennist
If you do need any internal parts, let me know as I have a hydro trans axle torn apart and all the gears are in great shape.-Dennis
ba2988
Started to work on the trans earlier this week. Hubs are stuck and have been soaking the last few days...good posts here with ideas on how to get them off that doesn't work. Thanks for the offer dennist - I'll let you know once I get inside the trans axle.
ba2988
TT was 100% correct!
Finally got the left hub pulled and into the transaxle case. One of the bolts had worked itself loose and was jammed in the differential gears. To my surprise there doesn't appear to be any damage - I had already picked up a differential assembly for $10 off ebay and it has the bolts.
Now I just have to get the right side hub off to fix.
HankB
Thanks for following up with what you found.
Note to self... Give the hubs on my tractors another shot of PB Plaster in case I ever need to remove them.
kpinnc
Just a reminder here- ALWAYS use new locknuts (all metal, not the nyliner type) on the differential bolts. It will be very helpful in preventing the same thing in the future.
And keep the tranny CLEAN inside while it's opened up. You'll be glad you did! :)
