mattd860 162 #1 Posted August 6, 2010 I am looking at buying a 79 C-161 with a bad transmission. I haven't looked it over yet but the owner claims the trans will not go into low gear. It works in high gear in all speeds. I know this is very hard to diagnose with no information but are problems like this usually fixable or will it be better to just source a new transmission? Is there something common that usually breaks which prevents low range from being achieved? Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted August 6, 2010 i could be as simple as the roll pin broke in the high low shifter to the tab broke off the high low shifter arm in the tranny Share this post Link to post Share on other sites
rickv1957 73 #3 Posted August 6, 2010 Also could have a broken shift fork,Rick Share this post Link to post Share on other sites
mattd860 162 #4 Posted August 6, 2010 So it *might* not be something internally wrong with the transmission? Can the shift fork be replaced without opening up the trans? Share this post Link to post Share on other sites
JimD 3,345 #5 Posted August 6, 2010 No, the fork is inside the trans. Here is an excellent thread on rebuilding an 8 speed transmission. It has everything you need to see to do the job. http://www.wheelhorseforum.com/index.php?...topic=20140&hl= Share this post Link to post Share on other sites
Duff 206 #6 Posted August 7, 2010 Matt, just to reinforce what Jim's suggesting, have a look at that thread he's posted. Opening up a tranny really isn't all that daunting a task, and the fix is probably neither difficult nor expensive. Every so often I like to put out some advice to our newer members of our family: If you have an 8-speed tranny, NEVER shift from low to high range or vice versa while the machine is in motion. Stop, throttle down, put the gear shift in neutral, leave the clutch fully depressed and then change ranges. If the range selector sticks, gently rock the tractor with your body weight and finesse the shifter into the range you want. The 8-speed is a very strong tranny in many ways, especially compared to some of the other brands, but the shift fork for the range selection is a known weak point. Good luck! ~Duff Share this post Link to post Share on other sites
Polaris2007 4 #7 Posted August 21, 2010 I'll put my money on the shift fork. I had to replace the one in my C-120 (Micah's now) and it was a simple task. The part is available from Toro for around $35. You will want to buy a gasket and seal set too. Share this post Link to post Share on other sites
