jdog_kustoms
552 hot rod
TT
But my tractor buddy said the cub runs in the opposet direction than a Horse?
Is that true, anyone know?
Just the starter/generator - since it drives/runs off of the PTO side instead of the flywheel.
The engines all turn CW @ the flywheel.
jdog_kustoms
i figured id give this post a bump cuase this tractor is heading to my garage today and gona start it and i want to have it done by the show ansd more pics to come asap
jdog_kustoms
here are some pics of it as it is now before i tear it apart and do some custom work to it i will post pics as i go but im still desiding what engine to run in it maybe a 10 hp kohler maybe a 16 hp kohler maybe a honda clone maybe a twin 20 hp kohler k series
post-1653-0-11810500-1328566953_thumb.jp
post-1653-0-67193400-1328566999_thumb.jp
post-1653-0-93054000-1328567064_thumb.jp
Jake Kuhn
Very cool project! :handgestures-thumbup:
AMC RULES
My vote would be for the twenty horse Kohler. :icecream:
jdog_kustoms
maybe a v twin diesel ??? i guess i got a figure what engine so i can mod the hood and frame and all to make sure it all works before i do other stuff might just use my 10 hp kohler keep other engines for other projects
jdog_kustoms
does anyone know of a satin or sorta flat wheel horse red paint
Hodge71
Jordon, Krylon used to make Cherry Red in a satin finish. I used to get it at walmart a few years back
AMC RULES
Any progress yet? :text-bump:
jdog_kustoms
not yet iv been fixing my car hopefully soon
jdog_kustoms
well i picked up a set of wheels and tires for the project might be a little to wide they are 24x13-12 and the older ones are 23x10.5-12 the new tires are not even bolted on yet i need an aditional 3 inches for the wheel to be able to be bolted to the hub to customize or to not use them its a hard desition
post-1653-0-90084500-1342147344_thumb.jp
post-1653-0-13430900-1342147457_thumb.jp
Kelly
The one on the right is a 23x10.5 on the left is a 24x14x12, on a 8.5 rim off a 520 to give you a idea, they bolt on with no mods with those rims.
jdog_kustoms
ok so i take it the 520 rim has a lot smaller offset on the inside of the rim and i never new the 14 inch wide tires will fit on a 8.5 rim i have a set thats what was on it so ill have to smap the tires thanks kelly
Kelly
The 520 rims only have about 1.5" back spacing, if you look the rim on the right is a cub rim with more back spacing I think about 2.5" and I think it is a 8,5" rim also, and these tires are made for a zero turn with 8.5 rims they have a round sidewall maybe for a better ride, they would fit a wider rim I'm sure but I took them off a 8.5" rims with a 4 bolt pattern.
clintonnut
Do what I did with a command V-twin. WIll fit under the hood if you remove the shrouding.
Charlie
jdog_kustoms
i think my v twin vanguard is gona go in it since i got a deal on it and cant seem to find a command near me for sale
COMMANDO6
Cool project. I say go with the 14 inch tires, The wider the better.
roscoemi
Put those 14 wides on and you'll need an old mechanical injected 327 to burn them down properly and look wicked cool in the process! :teasing-poke:
jonsteffen
go with the 24's looks more beefy
Rooster
Use Da Big ones, big ones are better, they might attract another "tractor" with big ones.....just sayin', I'd use the big ones....
jdog_kustoms
if i use the wide ones im gona cut the center out and move it but was also thinking when i move it to make the tires and wheels at close as i can to the rear end then cut the tool box down to give it like a mini tubed look like on a car think it would look ok or would you just move the center more to make them fit
Rooster
Tubbed, totally! I would not move them in though, I would widen the fenders :)
jdog_kustoms
well after 6 long years this tractor will be at the show not owned by me but built by me here is that it looks like as of today
wallfish
Better get to work on it real fast quick and in a hurry!
6 years is enough procrastinating so now you gotta cram!
jdog_kustoms
It will be done don't have tons of stuff to get ready for show anymore I might even stop in and make an appearance at the show
