B-8074 19 #1 Posted July 25, 2010 :thumbs: I can not find any drain plug on my 69 Charger 12. Also the guy at the toro dealer said to just use 10w-30 instead of the type A fluid. Share this post Link to post Share on other sites
pfrederi 18,293 #2 Posted July 25, 2010 Plug id on teh bottom...need an allen wrench to open it. Fluid may have either one in there. Originally used ATF (Dexron) but some were converted to 10w-30. You do not want to mix!!. There are instructions about flushing the system if you change over (can't remember where). Frankly I would stick with what ever is in there now. If it is red it is ATF Dexron 3 works. If it is honey color it is oil 10-30 or 10-40. Share this post Link to post Share on other sites
