marshman 0 #1 Posted April 2, 2008 Hi, im new to this forum i have a commando 800 and a commado 8 I need a drive belt from the engine to the pully on the gearbox for the commando 800. Does anyone know what the part number is for one thanks :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #2 Posted April 2, 2008 :thumbs: Your Commando 800 should be a 1972 - model # 1-0110. The Toro P/N for the drive belt is 7473 (82" long X 21/32" wide) which also crosses to Gates 6982. DO NOT buy a cheap rubber-coated belt or you will have declutching problems. Share this post Link to post Share on other sites
marshman 0 #3 Posted April 2, 2008 Thanks the model number on the frame says 1-0141 but i cant seam to find that anywhere? Share this post Link to post Share on other sites
CasualObserver 3,410 #4 Posted April 2, 2008 Ummm... that's the model number of a B-80... same as mine? Horizontal Kohler 8HP... nothing at all like a vertical Commando 800... someone switched your hood. Share this post Link to post Share on other sites
combatmp29r 27 #5 Posted April 2, 2008 :D Model 1-0141 is a 1975 B80 garden tractor. Perhaps someone changed the dash tower on your comando 800, or its actually a B80 with a commando 800 tank support and badges :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #6 Posted April 2, 2008 1-0141 is a 1975 B-80 4 speed. (I have one too.) It still uses the same belt. You can find a parts list for it HERE. Share this post Link to post Share on other sites
combatmp29r 27 #7 Posted April 2, 2008 Uhhhh Jason a commando 800 is a horizontal shaft with the samll 10" rear tires on it The Verts were V8s in 69 and just 8s in 70. Oh and Sheesh your fast LOL :thumbs: Share this post Link to post Share on other sites
CasualObserver 3,410 #8 Posted April 2, 2008 whoops... my bad was thinking of the ranger 800 auto.... thanks Joel! Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #9 Posted April 2, 2008 Marshman, I don't have anything to add as the rest of the guys here have you covered. But I want to And as always, :thumbs: Share this post Link to post Share on other sites
marshman 0 #10 Posted April 2, 2008 Thanks veryone and thanks for the welcome How can i whats what whats the diffence bettween a commando 800 and the b thanks Share this post Link to post Share on other sites
marshman 0 #11 Posted April 2, 2008 Ummm... that's the model number of a B-80... same as mine? Horizontal Kohler 8HP... nothing at all like a vertical Commando 800... someone switched your hood. sorry just relised you told me :imstupid: Share this post Link to post Share on other sites
nylyon-(Admin) 7,427 #12 Posted April 2, 2008 Marshman, welcome to RedSquare glad you found us and :thumbs: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #13 Posted April 2, 2008 Here's a link to the picture gallery thread that shows the Commando 800: Commando 800 pictures Share this post Link to post Share on other sites
marshman 0 #14 Posted April 2, 2008 Thanks guys, just been on the phone to the dealer i brought it from and after a bit of dective work it is a commando 800 as the isnt a direct shaft to the cutter deck? is this right sorry for my lack of knowlage on this. If i cant find out do you reckon you could identify it if i put a picture up thanks Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #15 Posted April 2, 2008 Study the pictures. A B-80 will have a little more room between the grille and engine and the grille and hood swoops forward at the top. The Commando 800 has less room between the grille and engine and will have more of an upright grille. Also the hoods on the B-80 seem longer than those on a Commando 800. If the tractor still has the id plate, there is where I would start. :thumbs: Share this post Link to post Share on other sites
nylyon-(Admin) 7,427 #16 Posted April 2, 2008 Get the numbers. You have the numbers from the frame, next get the numbers from the engine, model, and spec. Pictures will help as well. In my opinion, it is more likely that the hood was swapped rather than the hood stand (where the ID tag is) making it the B-80, but you never know. Share this post Link to post Share on other sites
marshman 0 #17 Posted April 2, 2008 ok bit more dective work and studying the pics, i has a b 80 bonnet and the engine is futher back like you said will go and get the numbers off the engine and takes some pics Share this post Link to post Share on other sites
nylyon-(Admin) 7,427 #18 Posted April 2, 2008 Would you by chance be a new U.K. member? The bonnet gives it away... Share this post Link to post Share on other sites
marshman 0 #19 Posted April 2, 2008 Would you by chance be a new U.K. member? The bonnet gives it away... you guessed it, it was a test Hope thats ok its not just an us site is it? thanks for the help just going to attemped to put a pic up of it i think its a b-80 Share this post Link to post Share on other sites
nylyon-(Admin) 7,427 #20 Posted April 2, 2008 We have a great U.K. representation here at RedSquare and I am sure they will chime in soon. Share this post Link to post Share on other sites
marshman 0 #21 Posted April 2, 2008 Um hope this isnt going to far off topic but how do you add a picture :imstupid: :thumbs: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,539 #22 Posted April 2, 2008 You're more than welcome here. You're about our 5 UK member, along with Ian (Stigian), Jim (Mith), Wesley, and Gerry. I hope I didn't leave anyone out. :thumbs: Share this post Link to post Share on other sites
marshman 0 #23 Posted April 2, 2008 You're more than welcome here. You're about our 5 UK member, along with Ian (Stigian), Jim (Mith), Wesley, and Gerry. I hope I didn't leave anyone out. Thanks :thumbs: Share this post Link to post Share on other sites
nylyon-(Admin) 7,427 #24 Posted April 2, 2008 Um hope this isnt going to far off topic but how do you add a picture :imstupid: Check here for an example using Photobucket. http://www.wheelhorseforum.com/index.php?showtopic=1071 You can use any picture host you wish the instructions should be similar. Share this post Link to post Share on other sites
marshman 0 #25 Posted April 2, 2008 Hope this works thanks Share this post Link to post Share on other sites
