clintonnut 127 #1 Posted June 29, 2010 I have been moving lots of dirt with the 876 and using it pretty hard. The hydro is plenty strong in foward and the engine will stall before it slips but reverse is slow and takes a couple seconds for enough pressure to build up before it starts to move. I noticed there is a set screw on the front and back of the pump. Do these have something to do with the pressure? Wheel speed? Charlie Share this post Link to post Share on other sites
clintonnut 127 #2 Posted June 29, 2010 anyone? Charlie Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted June 29, 2010 The 1 3/16" hex-headed things with the set screw sticking out of the middle of them are the acceleration (dampening) / relief valves. The front one is for reverse and can be removed and cleaned without much trouble. (The one for forward travel requires removing the fender/toolbox for access) Turning the set screw will adjust the spring pressure, but I would start by cleaning the valve. It's possible that the spring is broken, so you might want to swap them and see if you get the same results, but only in the opposite direction. Share this post Link to post Share on other sites
clintonnut 127 #4 Posted June 29, 2010 Just tried to move the set screw. Won't move then tried the hex. That won't move. Need the breaker bar Charlie Share this post Link to post Share on other sites
rickv1957 76 #5 Posted June 29, 2010 The piston valves are different for forward and reverse so you cant swap them,maybe you can swap springs though,Rick Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted June 29, 2010 The piston valves are different for forward and reverse so you cant swap them,maybe you can swap springs though,Rick The dampening valves are the same for forward and reverse. Yes, Rick - the relief valves are different. :thumbs: Share this post Link to post Share on other sites
