Iggy68 28 #1 Posted June 28, 2010 I was working on the 953 Saturday, I was adjusting the brake to the idler puller. I had the tracter running and shut it off to make some adjustments. Went to start her up again and nothing, absolutely nothing. I have the lights wired so they can be turned on without the key being on. I flipped the switch and all I got was a dim glow. I THINK i have narrowed it down to a bad switch or the push button starter switch. If I hook a battery charger up it trips the safety breaker inside the charger. Something seems to grounded out. If it isn't either one of the switches, besides a bare wire, could the starter or regulator cause the same type of short? Share this post Link to post Share on other sites
WH nut 553 #2 Posted June 28, 2010 It sure could, start unhooking wires untile it doesnt trip the charger and you will know what it is Share this post Link to post Share on other sites
rickv1957 72 #3 Posted June 29, 2010 Regulater could possibly stick,but a bare wire or one hooked up wrong also would do it,Rick Share this post Link to post Share on other sites
