dgjks6
axle length question
dgjks6
I am trying to replace a broken axle from 312-8 transmission. I found one that is 10 5/8 long, the correct diameter, and the correct number of tines.
I think mine is 11 3/8 but hard to measure because one is installed.
Would it be a problem to install 1 inch shorter axles?
stevasaurus
I see no takers on this :USA: ...my 2 cents...the hubs will not fit correctly and the fenders may come into play. In other words...you need the correct axle length. :wh:
Those parts are out there. :D
