Docwheelhorse 2,683 #51 Posted June 15, 2010 Yah Yah Yah... So he did the EASY part and built the tractor by hand completly out of stainless ... I'm waiting for the pics of the solid block of stainless being machined into the K91 Kohler or the Clinton!!! AWESOME JOB!!! Tony Share this post Link to post Share on other sites
buckrancher 2,694 #52 Posted June 15, 2010 Guess I'll be the one to ask, when casting your steering wheel, what the heck was the crayon for? Just filling the hole where your poured the resin in? the crayon was used to form the pour hole for the casting resin when I made this mold as the rtv silicone mold compound will not stick to wax Share this post Link to post Share on other sites
jachady 130 #53 Posted June 15, 2010 I can't wait to see this done. I hope you plan on using original sheet metal and painting that red. That'll make for one good looking tractor. I do have two issues I noticed in the pictures. First, the front suspension stops would be at the wrong angle if the front axle is against them. They'll definitly stop the axle but they might leave a mark in it. Second, I question the usabilty of your front spindle design. I know that the factory spindles have a rake to them that is there for a purpose. I can't recall if it is for caster to help the tracking or Ackerman which makes the inside tire turn more than the outside tire, or just for ease of steering. If this tractor is just going to be for looks you should be fine, but if you plan on driving or using it, you might want to research that a little farther. I wish I had your fabricating skills. Share this post Link to post Share on other sites
buckrancher 2,694 #54 Posted June 15, 2010 I can't wait to see this done. I hope you plan on using original sheet metal and painting that red. That'll make for one good looking tractor. I do have two issues I noticed in the pictures. First, the front suspension stops would be at the wrong angle if the front axle is against them. They'll definitly stop the axle but they might leave a mark in it. Second, I question the usabilty of your front spindle design. I know that the factory spindles have a rake to them that is there for a purpose. I can't recall if it is for caster to help the tracking or Ackerman which makes the inside tire turn more than the outside tire, or just for ease of steering. If this tractor is just going to be for looks you should be fine, but if you plan on driving or using it, you might want to research that a little farther. I wish I had your fabricating skills. I have two RJ58's all parts are copyed from the original parts same location, angle etc.etc. In some places I increased the tube dia from 1" OD to 1 1/8" for using flanged bronze bushings(front axle ends and lower steering wheel shaft support) otherwise this is a copy of a original only in stainless steel :D Share this post Link to post Share on other sites
buckrancher 2,694 #55 Posted June 15, 2010 fabbed up a new stainless brake band and epoxyed in material that I remove from a original rj brake band transmission assemby you can see the new belt tensioner pulley I turned out of stainless made mine with a sealed bearing held in with snap rings Transmission bolted to the frame :D 1 Share this post Link to post Share on other sites
Butch 194 #56 Posted June 15, 2010 You guys and your talents are really starting to piss me off. Damn Buzz. Why can't you do stuff like this? Butch S. Jersey Share this post Link to post Share on other sites
Horse Fanatic 49 #57 Posted June 15, 2010 Absolutely beautiful!!! Really loving seeing these progress photos!!! Keep them coming!!! Glenn Share this post Link to post Share on other sites
Suburban 550 28 #58 Posted June 15, 2010 You guys and your talents are really starting to piss me off. Damn Buzz. Why can't you do stuff like this? Butch S. Jersey Wait til you see it at the show, Butch. I have the pictures of it all done. That is one talented man and one beautiful machine. :USA: Share this post Link to post Share on other sites
mavfreak 11 #59 Posted June 15, 2010 wow. I work with stainless every day and I to want to build an all stainless machine. I don't know if I'll ever compete with this though Share this post Link to post Share on other sites
buckrancher 2,694 #60 Posted June 16, 2010 I e-mail Joe papke about the reproduction belt covers he sells and found out that the guy who makes them for him could stamp me one out of stainless but could not weld it for me which I replyed I would take care of that I received a top plate and a flat strip so the first thing was to make a form I cut out the shape of the top cover in a block of wood and sanded the edges smooth.I drilled a small hole for a screw and fastened one end down then wrapped the piece around the form mark and cut the part to length drilled another hole an fastened the strip down added the top plate its ready to be welded after the parts were welded together I used a angle grinder and a sanding disk to smooth out the welds and then sanded the whole piece with a foam sanding block :D 1 Share this post Link to post Share on other sites
Kelly 1,030 #61 Posted June 16, 2010 Words will never tell you how cool this is, your craftsmanship is awsome, but I want to know what this is costing???? you must get a killer deal on all that stainless, heck I have a hard time buying stainless bolts, let alone build a tractor again this is very nice, can't wait to see the end product :D Share this post Link to post Share on other sites
dobeleo 7 #62 Posted June 16, 2010 I found the time and money I spend rebuilding mine is far cheaper then the meds I would need to take for stress relief! Share this post Link to post Share on other sites
stoneman 10 #63 Posted June 16, 2010 that thing is ridiculously sic got anything in a ss weed whacker? :D Share this post Link to post Share on other sites
dclarke 4,046 #64 Posted June 16, 2010 Brian, this build just keeps gettin better and better. AWESOME JOB. :D Share this post Link to post Share on other sites
buckrancher 2,694 #65 Posted June 16, 2010 I found the time and money I spend rebuilding mine is far cheaper then the meds I would need to take for stress relief! :wh: Share this post Link to post Share on other sites
rickv1957 72 #66 Posted June 16, 2010 Excellent workmanship there! Rick Share this post Link to post Share on other sites
Mrs. Ed 0 #67 Posted June 16, 2010 Awesome, just awesome. :D Share this post Link to post Share on other sites
canam1991 2 #68 Posted June 16, 2010 This thing is going to look awesome :D Share this post Link to post Share on other sites
Buzz 502 #69 Posted June 16, 2010 Damn Buzz. Why can't you do stuff like this? There are at least a half-dozen reasons Butch: 1/ don't have a work place as well equipped as Brians 2/ don't have the skills 3/ don't have the time 4/ don't have the skills 5/ don't have the patience 6/ don't have the skills Do you see a pattern developing? Share this post Link to post Share on other sites
Butch 194 #70 Posted June 16, 2010 Yeah I do. You have a forward slant after all your numbers! Don't have the time? You have over 1300 posts. That's 2 ground up restos with custom work right there. Butch S. Jersey Share this post Link to post Share on other sites
littleredrider 409 #71 Posted June 17, 2010 I'm not too far from Mecklenburg, I'd love to come up and take a closer look at this. But I know if I do, I'm gonna want a ranger built out of stainless!!!! (I like lawn rangers sorry) I wish I had half the talent, maybe I'd get something done.... coming along very nice..... :D Share this post Link to post Share on other sites
buckrancher 2,694 #72 Posted June 17, 2010 I had a kohler k91 that I pick up some time ago for a different tractor but deicided to use it on this one I took her a part and mic'ed everything replaced the rod ,honed the bore and new rings and did a valve job also points ,plug,carb rebuild, new air cleaner assembly had the recoil ,ponts cover and gov. arm gold zinc plated to match the new air cleaner you can see the toolbox it was made out of 12ga stainless heat shield when the engine was apart I bored the exhaust port and pluged the tapped holes and threaded for 3/4" npt heat shield in place engine has a stainless dipstick belt guard wheel rims and seat were powder coated white used a gear oil bottle for a quick a easy gas tank :D 1 Share this post Link to post Share on other sites
Butch 194 #73 Posted June 17, 2010 I would hope that Kohler engine cover is CNC'd out of a solid block of stainless steel or aluminum and then anodized red and not just some normal cover like the rest of us have that we sandblast and paint! Heck, Buzz and I could do that! Butch S. Jersey Share this post Link to post Share on other sites
Horse'n Around 22 #74 Posted June 18, 2010 Schaaaaawing! John Share this post Link to post Share on other sites
rickv1957 72 #75 Posted June 18, 2010 Awsome Work there! Rick Share this post Link to post Share on other sites
