buckrancher
The Wheel-horse Delorean model
VinsRJ
Very nice! Can't wait to see it :D
markslawnmowerworld
Those welds are amazing......and what a nice project.
can't wait to see more pic's :D
Horse'n Around
Wow, Im in awe! I hope to get to see it in person one day. Calling that a work of art just doesnt do it justice!
:D
John
bo dawg
That's just amazing! Can't wait to see it done. That is the smoothest looking weld job I've ever seen :D
JimD
Brian, this is an amazing project. Can't wait to see the finished tractor, You have a gift. :D
horsefeathers
Buckrancher, I have a question. When you weld stainless do you get discoloration?
And if so how did you polish it off? Just buffing, or is there a secret wepon?
Great talent and amazing skills!
And just think this :D could surive for many decades, long after most :USA: rust back to earth!
I'am a big fan of your work!
Keep the good stuff comming!
:wh: HORSEFEATHERS!
buckrancher
:wh: HORSEFEATHERS!
Thank you
Being that everything stainless is Tig welded the discoloration area is small
and close to the weld a regular foam sanding sponge will remove it
I had decided to use a one direction sanded finish(brushed) on all the stainless as it hides imperfections and is much easier than trying to polish to a mirror finish
(as I do not have large buffing wheels)
DMK855
Brian, you do amazing work. :D Can't wait to see it at the show!!
Dwayne
Indy w h
Brian,great job!! :D
Just make sure you leave room for the flux capacitor
:USA:
Indy
Ken B
Truly a work of art! What a work of craftsmanship and dedication. :D
Duff
Oooohhhh - that's going to give it a really nice finish! Wow!!!!
Duff :D :USA:
buckrancher
Thank you all for your comments
Rear hubs were made from two pieces and welded together
gear shift lever
:D
racinfool40
Very nice work And Hats off to the Welder and Machinists :D can't wait for the finished product. Keep up the Great Work!!!
chris11
gear shift lever
:D
do you have to broach for keyway? I have the size if you need it.
rickv1957
Super quality work there!! :D Rick
Coadster32
Awesome stuff! :USA: Expectations are high coming off the 854 job you did. Looks like you're living right up to it! :D
buckrancher
At first I was going to use a stock steering wheel but for some reason I
could not leave it be.So after some thought this is what I did. I bought
some rtv silicone rubber moldmaking compound and some black casting
resin
First thing was to make a mold from a good steering wheel
Next I made a new center hub and spokes with some engraveing
At this point I cut plastic grip off the old wheel at the joint and sawed the old hub and spokes out of the steering wheel also whipped up a fixture to hold everything
for welding in the new center
new hub and spokes welded in I did this with my mig and stainless wire
once the new stainless pieces were welded in I recast the spoke joint
All recast you can see the pouring sprues sticking up
Done removed the sprues sanded smooth and painted with krylon fusion gloss black
bottom side I used brass to pin the spokes in the hub
:D
C-Series14
Very nice!!! :D
btrrg1969
that is way cool :D
bell
FANTASTIC!!! :D
Duff
Just plain AMAZING work!!!! :D
Duff :USA: :wh:
Buzz
Now you're just showing off.......... :wh::D :USA:
Horse Fanatic
Holy crap, that is very cool!!!!
tgranthamfd
Guess I'll be the one to ask, when casting your steering wheel, what the heck was the crayon for? Just filling the hole where your poured the resin in? :D
JimD
Guess I'll be the one to ask, when casting your steering wheel, what the heck was the crayon for? Just filling the hole where your poured the resin in? :USA:
He uses that to draw the blueprints... :D
