ericschevy
C-141 Trans fluid
ericschevy
Hey guys, I just picked me up a C-141 (8 speed manual)and noticed there is water deposits in the trans. What type of fluid do I use in it? Thanks..
C-Series14
Lube and belt chart says 2 qts.
SAE 90-140 API Service GL-5 Gear Lube
Duff
Eric, you probably already knew this, but flush that tranny really well before adding the new lube!
Duff :D
The Toolman
put a new boot on the shifter to stop that water getting in
ericschevy
Yeah, I later realized that the boot is missing. What's worse is that this tractor had been stored outside..YIKES!!
ericschevy
Duff :D
Would it be safe to use engine flush? All it is kerosene..
rickv1957
That will work fine,I use deisel fuel,Rick
