tbbahner 27 #1 Posted June 9, 2010 Hey guys, picked up an old C85 - 6 spd swapped out for a 3 spd. Would the 6spd out of a Raider swap over to the C85.?? Any major hurdles to be crossed ?? Any info appreciated. Thanks Tom B Share this post Link to post Share on other sites
rickv1957 73 #2 Posted June 9, 2010 That trans should bolt right in,Rick Share this post Link to post Share on other sites
tbbahner 27 #3 Posted June 10, 2010 Thanks Rick. Thought it should be about the same. Tom B Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #4 Posted June 10, 2010 What year or model# is the Raider tranz? The first ones had the brake drum mounted to the pinion shaft and will require minor brake linkage mods to work in a C series. The hi-lo shifter is also a little different in later years and may need bent a little to work in your C. Share this post Link to post Share on other sites
