Mrs. Ed
D-200 3-Point Hitch Help
Mrs. Ed
Hello all, I have a :USA: D-200 and was mounting a D-series 3-point hitch (bought separately) and found a problem. The piece that is called the "Lift Assembly", (Part# 102100 on the parts list diagram) is bent. This is the part that rotates and is attached to the hydraulic cylinder to raise/lower the implement. One of the arms that the adjustable side links attaches to is bent severly inward.
Can anyone tell me the center-to-center distance of the arms at the pivot balls so I can bend it back? :D
rickv1957
Heat it up with a torch and unbend it!,Rick
Duff
Rick, I think that's what she wants to do...she just needs the measurements! :D
Duff :USA:
rickv1957
Oops,Polly,the rockshaft arm is 13" center to center wide, :D:USA: Rick
Mrs. Ed
Yeah Rick, that's what I want to do! :USA: Thanks for the help. :D
rickv1957
Polly,your welcome!!! :USA: Rick :D
