6wheeler 670 #1 Posted June 1, 2010 Ok guys, I'm officially confused I am trying to look up some parts for the 165. I went on the master parts viewer sight and though it says I can order parts of an assembly separately, I cannot figure out how.(mostly I believe, it is because of my masterful prowess with this computer thing ) Any way to compound the confusion, I didn't know which forum I should choose. So, I chose this one.. Chastize, belittle, mock or simply make fun. I can take it ... IF, you can help me. Pat Share this post Link to post Share on other sites
rmaynard 16,690 #2 Posted June 1, 2010 What specifically are you looking to order? Bob Share this post Link to post Share on other sites
Duff 206 #3 Posted June 2, 2010 Chastize, belittle, mock or simply make fun. Nope, no dissing here when someone is trying to get some help! Like Bob said, can you give us an idea of what exactly you're trying to order? Duff :D Share this post Link to post Share on other sites
6wheeler 670 #4 Posted June 3, 2010 Sorry guys, Just got back to the computer. What I am trying to get, are parts for my clevis hitch. The bell crank that I have is for an older tractor I think. I would like to get one that has the slots in it, also I need the cable and trunion and clevis. I have the assm. drawing with the part #'s but on the websight or even in the toro store, when I type in the part number it says it can't be found. I made a cable and such, but I cannot either get my implements to lift high enough, or go down low enough. This I believe is because of the limited adjustbility and with the proper parts I may be able to achieve that. Thanks for your help Pat Share this post Link to post Share on other sites
rmaynard 16,690 #5 Posted June 3, 2010 What are the part numbers you are looking for? Share this post Link to post Share on other sites
tgranthamfd 29 #6 Posted June 3, 2010 Pat, I have had trouble on the Toro sight, as well. If you find the needed part numbers and go to another parts sight, such as rcpw.com, they can get you your Toro / Wheel Horse parts. There are a few of these parts sights listed in the pinned stuff at the top of the WH tractor page. Hope this helps. You said you have all the drawings and part numbers that you need, right? Did you get the manuals I sent you in a private message? Terry Share this post Link to post Share on other sites
6wheeler 670 #7 Posted June 6, 2010 Thanks Terry, I got the manuals. I am/ was using the part numbers on the assembly drawing such as #110044/ lever asm. But, it says cannot find part or #. Maybe I need a toro prefix or something like that. Bob, do you know if a prefix is necessary? Or maybe the part no. on the assembly drawings is totally different from the actual number? The form # is 3322-959.Clevis hitch. it has the complete assm./ with what I thought were the part #s. Any Ideas? Or maybe I cannot get parts separately w/o buying the whole thing. Pat Share this post Link to post Share on other sites
gwgdog66 23 #8 Posted June 6, 2010 Thanks Terry, I got the manuals. I am/ was using the part numbers on the assembly drawing such as #110044/ lever asm. But, it says cannot find part or #. Maybe I need a toro prefix or something like that. Bob, do you know if a prefix is necessary? Or maybe the part no. on the assembly drawings is totally different from the actual number? The form # is 3322-959.Clevis hitch. it has the complete assm./ with what I thought were the part #s. Any Ideas? Or maybe I cannot get parts separately w/o buying the whole thing. Pat I found the part on RCPW.com http://www.rcpw.com/search/?quest=110044&search=Search It has a replacement number now Share this post Link to post Share on other sites
