wedgeheaded
blown fuse
wedgeheaded
I remotored my SB421 years ago with a 12hp kohler from Northern. It has a toggle switch and dimmer switch start button, that's how I left it. Lately it keeps blowing fuses. It didn't blow them in the thinned out part of the fuse like you'd expect, it melted out the sodder in the end of the fuse. After changing that fuse about 3 times in as many hrs, the lightbulb came on. I had a bad fuse holder! I changed the holder and have had no trouble since. Just thought I'd share and maybe save somebody some time and trouble.
Save Old Iron
A corroded contact in the fuse holder is heating up the metal end cap of the fuse and actually melting the solder which holds the fuse element inside the fuse body.
Corrosion = resistance
Resistance with high current flowing it = high voltage drop
Voltage drop across resistance = heat generated
Heat at the fuse contact heats the fuse body and melts the inner solder connecting the fuse element to the end cap.
I have seen this before many times on older fuse holders.
