grandpa clair
hydro tranny
grandpa clair
while running tractor, fwd. movement stopped and will not move under own power. am able to push tractor freely without opening tow valve. anyone know what is wrong and how to adjust it?
grandpa clair
KB9LOR
How is the tranny fluid level? Could the tranny filter be plugged, those are designed not to have a by-pass valve in them to prevent hydro damage if filter becomes clogged. hope this helps.
rickv1957
Hellom and :D Rick
TT
:USA:
What is the year/model of the tractor? :D
Did you happen to check the axle to wheel hub woodruff keys?
grandpa clair
yes thanks rickv1957 I did check the woodruf keys, they are ok
and I did check for fluid level, did not think about the filter. will check it out.
Hydro press seems to be good as it raises the mower deck quite vigerously.
Thanks KB9LOR
TT
  TT said:
What is the year/model of the tractor? :USA:
Can we get a hint? :D
grandpa clair
my tractor whith the hydro problem is a 79 model C-161-A
Grandpa Clair
tophatbufflo
Try to adjust the friction on the directional control lever.
