Prater
No D series Tri Ribs???
Prater
Checked with miller and he does not have tri ribs in 18x8.50-8. He recomended a 5 rib tire but it does not look like it will bite as good in the garden. Anyone know of any correct size tri-ribs?
Operator
The Miller Tri's measure up right for height against my D-200, :D
I'm going to order some this summer.
Randy
rickv1957
I know they have 16x6.50x8,I think they would look good on a D,Rick
tgranthamfd
Steven did you look at the Deestone or the Vredestine? The Vredestine looks like it has more of a gap in between the ribs, than the Deestones. They may look better if you could see them aired up, too. If you get them and they are not cutting the mustard you could always do the roller chain trick around the center. Just some thoughts.
Nick
Are the tri ribs a little shorter than the original D tires also the D rims are a bit wide could that spread the tire out more than on other tractors? :D
