groh_brian 0 #1 Posted May 22, 2010 Does anyone know if the raider series tractors with the 6 speed are any good for pulling or should I find an 8 speed? Thanks, Brian. Share this post Link to post Share on other sites
KeithB 6 #2 Posted May 22, 2010 change it to 8 speed 8 pinion Share this post Link to post Share on other sites
groh_brian 0 #3 Posted May 23, 2010 I am new to this and was wondering which tractors had the 8 speed 8 pinion? Share this post Link to post Share on other sites
rickv1957 73 #4 Posted May 23, 2010 The newer tractors had the 8 speed mid 70s and up,Rick Share this post Link to post Share on other sites
Raider12puller 1 #5 Posted May 23, 2010 I am new to this and was wondering which tractors had the 8 speed 8 pinion? most of your c-series, B80 and B100, 400 and 500 series. Share this post Link to post Share on other sites
chris11 184 #6 Posted May 23, 2010 im not to sure you will ever use the low gears for pulling. i think a 3 speed would be fine. Share this post Link to post Share on other sites
groh_brian 0 #7 Posted May 23, 2010 I know it all depends on track conditions and weight class, but what gear do you guys pull in? Share this post Link to post Share on other sites
Bill 4 #8 Posted May 24, 2010 I know it all depends on track conditions and weight class, but what gear do you guys pull in? We pull a stone Boat in our club and with my wheel horse running in the 1200 lbs class I always use first gear high range up until the weight gets around 2700 lbs, after that I go into Third gear low range, for the most part.. But you still have to watch the track I don't know what the guys pulling a sled use Share this post Link to post Share on other sites
mavfreak 11 #9 Posted May 24, 2010 i don't pull but i did switch over my commando 800 to an 8 speed, best thing i ever did much much more versatile. i broke the original 4 speed and no problems as of yet Share this post Link to post Share on other sites
MRM 4 #10 Posted May 24, 2010 I will use hi range up to 2500- 3000 lbs and then start with low range 4500-6000lbs 1st low. Share this post Link to post Share on other sites
baerpath 517 #11 Posted May 24, 2010 Not sure where your from but the Raider will be fine to start with. Just remember it has a weak transmission. My son started with a Raider 12, we trashed to 10 pinion trannies in it one weekend and then put an 8 pinion in it. We usually use 2nd and 3rd high for pulling. Duane Share this post Link to post Share on other sites
Jim_M 179 #12 Posted May 24, 2010 My puller started life as a Raider 12. It has an 8 speed in it now from a later model 300 series. Share this post Link to post Share on other sites
Polaris2007 4 #13 Posted July 17, 2010 Okay what am I missing here??? The raider's 6-speed IS an 8-speed. I have a 1970 Raider 10 that says 6-speed on the side, but it is the same transmission as my c-101 has......1 1/8" axles, hi and lo range, 3 forward gears and one reverse. I assumed that back then they called it "6-speed" because they didn't count the two reverse speeds. Please enlighten me here.......... :thumbs: Share this post Link to post Share on other sites
baerpath 517 #14 Posted July 17, 2010 Okay what am I missing here??? The raider's 6-speed IS an 8-speed. I have a 1970 Raider 10 that says 6-speed on the side, but it is the same transmission as my c-101 has......1 1/8" axles, hi and lo range, 3 forward gears and one reverse. I assumed that back then they called it "6-speed" because they didn't count the two reverse speeds. Please enlighten me here.......... Nope there not the same trans. The Raider would be a 10 pinion and the 101 would be a 8 pinion. The 8 solid pinion is a lot stronger than a hollow ten pinion is. Also theres the 4 pinion from the 300 series and the Work Horse line (All had 1 inch axles so easy to check) Duane Share this post Link to post Share on other sites
Polaris2007 4 #15 Posted July 17, 2010 Thanks for the info. So then it IS posible to have 1 1/8" axles, and 10 pinions? I think that is what my '70 Raider 10 must have? Share this post Link to post Share on other sites
qd-16 14 #16 Posted July 17, 2010 Yes. it is possible to have the larger axles and 10 pinions. Share this post Link to post Share on other sites
