ricksrj58 273 #1 Posted May 19, 2010 is 55 the only year that had a smooth hood or did it go into 56 also? Share this post Link to post Share on other sites
CasualObserver 3,408 #2 Posted May 19, 2010 Yes it continued into sometime in 56. (If the pictures look too small to read, click them for a larger version) Share this post Link to post Share on other sites
ricksrj58 273 #3 Posted May 20, 2010 i figured the smooth hood went into 56 also,i guess there is no way to really tell which year my tractor is, late 55 or early 56 Share this post Link to post Share on other sites
VinsRJ 721 #4 Posted May 20, 2010 i figured the smooth hood went into 56 also,i guess there is no way to really tell which year my tractor is, late 55 or early 56 You are correct, Pond was using whatever they had in stock at the time. And that pretty much holds true throughout the RJ run from 55-59. So pin pointing exactly what year you may have is diffucult. Without original paper work you need to measure these tractors with a thumb not a micrometer. Share this post Link to post Share on other sites
