tmix
Wiring STILL NEED HELP !
tmix
12 RAIDER-- Kohler MOTOR
2 wires coming from stator plate going to rectorfier DOES it matter what wire goes were they are not color coated. There are 3 plugs on the rectorfier 2 that go to the stator and the other one to the key which would be power PLEASE HELP ! TOM
I don't want to hook them up wrong !!! THANKS GUYS :D
rmaynard
The wires from the stator connect to either AC lug on the rectifier. The other lug on the rectifier is B+ and is the output where the 14V DC comes from. The stator produces AC voltage which is non-polarized. Either stator wire can be connected to either AC lug. The B+ lug on the rectifier goes to the key switch.
Bob
WH nut
Maynard got it, and I believe the center terminal goes to the key
tmix
thank you Did NOT want to blow somthing out :D:USA: tmix works great
TT
Not always......
There were different terminal configurations and different manufactures, so the B+ terminal could actually be any one of the three.
It might take some cleaning and maybe even a magnifying glass, but you should see "B+" stamped or cast near one of the terminals, and "A.C." near the other two.
