Paul Murphy 0 #1 Posted May 18, 2010 I need some help from anyone. I am trying to get C-125 starting woes sorted out for my father who is 88 years young. He had problems this spring so I brought it home to attempt to work on it. I have a wiring schem. downloaded from Toro but as most know they are B/W pdf files. Color helps me alot. I cant get the Koh. 12hp to turn over unless I jump the solenoid. Put a new original switch, and solenoid on but still no luck. When it does turn over,there is NO fire at the points(gapped to .018-.020) or naturally the s/plug. I am lost.... There are some pics of the current condtion, please note the bypassed seat interlock and clutch interlock wires. Share this post Link to post Share on other sites
MikesRJ 552 #2 Posted May 18, 2010 :D Colors may not do you any good. WH never stuck to the same color coding consistently. I would suggest you trace your wiring by-hand and annotate your manual. Also, the following link may help you, or at least give you another copy. C-125 Owners Manual Share this post Link to post Share on other sites
Paul Murphy 0 #3 Posted May 19, 2010 Thanks a million Mr. Mike! Your reply is a great help. Have a good day up there in PA. Share this post Link to post Share on other sites
rmaynard 15,535 #4 Posted May 19, 2010 If no one has said it already. Nice to have you aboard. If you don't mind saying, where are you from? Bob Share this post Link to post Share on other sites
Helmer 0 #5 Posted May 19, 2010 I had a similar problem on my C-101. Turned out the wires connected thru the ammeter were loose. Once I fixed te connections all was well. Your problem may be elsewhere but I figured I'd tell you anyway. Good luck. Share this post Link to post Share on other sites
Paul Murphy 0 #6 Posted May 22, 2010 Thanks for all the help guys. Any hints when your working "blind" is a great help. Did find a small hairline crack in the plastic or phenolic portion of the breaker points.That can't be good.Looks like I need to start some detailed wire tracing. BTW Mr. Bob, I'm located in a little place called Wedowee, Alabama. In the shadows of Mt. Cheaha. Real rural, real quiet, real pretty, and really the way I like it. Thanks for the "Welcome" :D Share this post Link to post Share on other sites
