rustbucket 4 #1 Posted May 18, 2010 So I finaly found something them green and yellow tractors are good for. I happened to be roaming at jacktown yesterday when me and my dad saw this short not sotall john deere snow plow blade sitting in a guys stall for sale. Not to shabby a Blade. came with the mount plate for if i had what ever john deere it was ment for and the rest of the bits heeded to work it. it fits under neith no cutting or chopping. i did flip it over though to raise the mount up higher but still needed to build drop links and brace arms. It lifts and lowers now all i need to do is rework my brace arms to move it forward under the tractor more so i can tilt the blade. it raises and lowers via a stainless steel wire rope threw a pulley to the lift sector of the big Allis. even got to play and move some of my drive way gravel around. well that is it for now when i finish getting it all just right ill post better pictures. Share this post Link to post Share on other sites
rustbucket 4 #2 Posted May 18, 2010 The blade was only 35 dollars the brackets are made from a dead non useable cutting edge from another plow i own cut up nicely and the cable and hardware are from TSC Share this post Link to post Share on other sites
rickv1957 77 #3 Posted May 18, 2010 Blade looks good!,Rick Share this post Link to post Share on other sites
rustbucket 4 #4 Posted May 19, 2010 Thank you Rick. I will have better pictures of how its mounted and actuates hopefully this weekend. Share this post Link to post Share on other sites
rustbucket 4 #5 Posted May 23, 2010 Okay as I promised pictures of how it mounts and hooks up plus i finished the tweaking and mods. The right sides mounting along with the pulley i used to route the steel cable threw to make forward and back into up and down motion for lift. Left side mounting system the cutting edge drilled and placed on the blade in its new position. where i lift at on the plow/grader. the hook up The finished project pushing drive way gravel. Share this post Link to post Share on other sites
