boovuc 1,090 #1 Posted May 16, 2010 Chuck, All, Thanks for your help on this project. I didn't post pictures until I was 100% sure I had good contacts everywhere. After tearing it down again and scrubbing the contacts on everything, I got power across the switch and the A terminal on the generator/starter. Some ether and a prayer, (plus a doush of the gass tank, lines and the pump), and it fired up. Boy does it need rings! Thanks for the help guys! BooVuc Mill Hall, PA Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted May 18, 2010 Just a tip don't use ether in these small engines, most carb or break cleaners work fine and will not hurt the alum rods like ether does or can. Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted May 18, 2010 BooVuc, Good to hear. Don't underestimate the value of THOROUGHLY cleaning the wiring terminals and connections. We did OK on this one - no pics and just 1 post. Koool! Share this post Link to post Share on other sites
paulgraham513@yahoo.com 0 #4 Posted August 6, 2024 have a raider12 with no points no solenoid,only the little black box with the spark plug wire. at one time earlier a jumper wire was run across 2 contact points that i cant for the life of me remeember. switch is good all contact points have been cleaned. engine wired with no accessories so only the i enginei is isolated.I have no visible magneto,but two wires coming from to the no spark..the crankase that dont show up on the wiring diagram. that jumper that i had has to be the answer can anybody explain the ignition flow thru thiss engine? Share this post Link to post Share on other sites
953 nut 68,947 #5 Posted August 7, 2024 @paulgraham513@yahoo.com It sounds like your engine wiring has been altered so the factory wiring diagram probably won't be a big help but I have attached a link to it. The Black Box you spoke about is probably a Capacitive Discharge Ignition system (CID). You can find several videos on the internet that explain how the work. Share this post Link to post Share on other sites
