onceyapop4
1985 310-8 something hanging
onceyapop4
I have a 1985 310-8 wheel horse that I picked up for free. I got it running and it cuts the lawn great. I was looking underneath and saw a metal rod just hanging. I can not figure out where it goes or what it is for. I can't seem to hook it up to anything and im not sure if I'm missing something. I am attaching some pictures. I need some help if anyone knows where it goes or what it's for. I can't seem to find any manuals online for this tractor or parts pictures. Thanks all for the help!
mowerman1193
I think that rod is supposed to hook into the hole down on the bracket that is welded to the bar that the deck wheels are on to keep the deck level..To keep the front to back level you adjust the tuinion thing until you get it level..
Kevin
mowerman1193
Well after looking again maybe not, LOL But you are missing the rod ( I think ) that I am speaking of as I think it mounts in the arm that goes up to the front of the deck and connects to one of the holes down on the bracket by the rollers..I would have to go look at mine to see what it looks like now but yours in not right anyway..
Kevin
Don1977
Here is where the rod goes.
onceyapop4
yea i can't seem to hook it to anything. maybe im missing another piece
onceyapop4
maybe i have something bent im going to have to take the deck off and look around because i can got it to hook up
Kelly
And another note your tractor is 85 or newer not a 1971
onceyapop4
so that rod was attached to the deck lift lever brackets to another hole is there suppose to be another rod or is that one just in the wrong place??
onceyapop4
to the date. the build date on the tag is 11/4/71. unless im reading something wrong how else would i find the build date???
onceyapop4
is this the code?? i thought the 11471 was date code.
C-Series14
The 310-8 is a 1985 or newer like said before by Kelly.
The silver rod with the trunnion does not go on the tractor. It looks like it is hooked in the lower bellcrank of the tractors lift arm. It goes where stated before, the trunnion goes in the hole on the rear wheel assembly of the deck and the "L" part goes in the hole on the flat stock that is seen in the side view of the deck like Don1977 posted with the pic.
OK, your pic shows us the VIN, 21-10K801, the SERIAL number 11471. The VIN tells me it's a 1985.
onceyapop4
ok thanks how does the vin read?? what do the numbers read?
C-Series14
Well, it can be confusing on the first number, 2. In my book, that stands for 1985 but on other some other models, the first number doesn't jive with the system. The second number, 1 is Garden Tractor. 10= the hp, K= Kohler, 8= 8-speed, and 01 is parts list code.
It is fairly easy to tell the hp, engine, and tranny from the VIN but the first number is no gaurantee!
For example:
21-10K801=1985
21-10K802=1986
21-10K803=1986
21-10K804=1987
21-10K805=1988
21-10K806=1989
NOW...
31-10K801=1990
31-10K802=1991
31-10K803=1992
GET READY!!!
73320=1993
See what I mean. Some other 1986 models are 31-xxxxxx
It is just safe to look in the book for the year! :D
onceyapop4
o ok thanks!! you guys have been very helpful
rickv1957
Nice looking tractor there!,Rick
gwgdog66
:USA: It's just hooked in the wrong place. It looks like it is hooked in the wrong place. Where it is hooked to in the second photo is the tractor lift arm. That hole is where a clevis pin would be hooked up to a cable if you had a rear clevis hitch for ground engaging attachments like plows and such.
Take it loose and hook it to the hole nearest the deck on the wheel rod, and to the center bracket. Like in the pic Don77 posted and you will be good. :D
