gardentracotpullinfool 0 #1 Posted May 13, 2010 i have heard of people use hydro internals in 8 speeds? not sure how it all works please help? :D Share this post Link to post Share on other sites
KeithB 6 #2 Posted May 13, 2010 8 speed , 8 pinion, 1 1/8" axle, Bs(like B80, B100) and Cs, 400 and 500 series have them they pull fine as they are Share this post Link to post Share on other sites
gardentracotpullinfool 0 #3 Posted May 14, 2010 is that what a c 105 has then? :D Share this post Link to post Share on other sites
rickv1957 72 #4 Posted May 14, 2010 8 speed , 8 pinion, 1 1/8" axle, Bs(like B80, B100) and Cs, 400 and 500 series have them they pull fine as they are Keith has it!! Rick Share this post Link to post Share on other sites
John Voss 76 #5 Posted January 18, 2012 I have a 1973 12hp with 8spd does it have teh 8 pinion rear? or how can I tell without opening it up? Share this post Link to post Share on other sites
Don1977 604 #6 Posted January 18, 2012 I have a 1973 12hp with 8spd does it have teh 8 pinion rear? or how can I tell without opening it up? From what I can find out from the Toro information your tractor should have a 5091 transmission with 4 pinions. The 1975 and later C-120 had 8 pinions according to the Toro drawings. Don't know if this information is right. Taking it apart is the only way to know for sure. Share this post Link to post Share on other sites
John Voss 76 #7 Posted January 18, 2012 According to this the 5901 has 8 pinion, It also appears that the 4 pinion model has 1" shafts and the 8 pinion has 1 1/8" shafts. Is there any truth to this? I will measure my shaft size if that is the case. http://www.mywheelhorse.com/graphics/file/10-8/Wheelhorse_6-8MechTransMan.pdf Share this post Link to post Share on other sites
stephan07 10 #8 Posted March 24, 2012 4 pinions had the 1" shaft and and 8 pinions had 1 1/8 just measured the origninal one from my 310 and and the 8 pinion thats in it now Share this post Link to post Share on other sites
