Countdown To Christmas!
tgranthamfd
Rectifier Test
tgranthamfd
Hey guys, is there any way to check the rectifier if it is not on the tractor? I read, on another thread, where he had continuity between 1 ac terminal and the B+, but not through ac #2 and B+. Is this normal? I checked mine, while off the tractor, and it was the same as his. What's your thoughts.
tophatbufflo
save old iron told me to use a 24VAC transformer like for a door bell -hook the output leads to the stator connection and test from the rectifer out put to the case and you should have around 14 VDC
