mowerman1193 32 #1 Posted May 9, 2010 I have never worked on a Wheel Horse with the electric clutch..Doing a motor swap from a Bronco 14 to a C-121..Was just looking it over a few minutes ago and wondering how the clutch is removed? Only thing I really seen was a bolt right on the end of the clutch.. Thanks, Kevin Share this post Link to post Share on other sites
rickv1957 72 #2 Posted May 9, 2010 Screw a 5/8" bolt into clutch as it will push against end of crank to remove,Rick Share this post Link to post Share on other sites
mowerman1193 32 #3 Posted May 10, 2010 Thanks for the great tip!! That will help a lot.. Kevin Share this post Link to post Share on other sites
Kelly 1,029 #4 Posted May 10, 2010 Put a washer on the end of the bolt, loaded with grease so you don't mess the end of the crank up. Share this post Link to post Share on other sites
mowerman1193 32 #5 Posted May 10, 2010 Thanks Kelly for the tip..I used to do that on cars for the pilot bearing, never would have thought of it on this clutch though, LOL Kevin Share this post Link to post Share on other sites
