Docwheelhorse
RJ58 Transaxle Oil Type/Qty
Docwheelhorse
Hello All,
I have added an RJ58 to my herd and was wondering how much gear oil it holds and whether it is acceptable to put in 80/90. Also... there is a 1/8" pipe plug about 1" up from the bottom on the "passenger" side of the transaxle behind the axle tube. I assume that this is where you check the level of the transaxle when its level... I also found the fill plug in the top of the transaxle. SO---where is the drain plug on this thing or is there none? :D
Thanks
Tony
markslawnmowerworld
my wheel horse lubrication recomendations manual from 1956-2005
starts at the year 1962 for transmissions and for that year it states 1 1/2 quarts of sae 90-140 hope this helps some... :D
clintonnut
I use 80/90 in all of mine.
To drain the tranny put the tractor on a slight incline and the case bolt that is lowest on the tranny, remove that to drain the oil.
Charlie
VinsRJ
Whats up Tony......
80-90 like Charlie said and I put in about 1 1/2 to 2 quarts.
Docwheelhorse
Hey Vin....
I pulled out a tractor for your brothers secret project.... Man has he got a nice garage/house.
Tony
