rmaynard
Look what followed me home
rmaynard
I have driven past this tractor at least once a week for the last 6 years. I didn't have a clue what it was, since it was always covered with a silver tarp. :D The owner was never home. I knew it was a Wheel Horse because of the shape of the hood, :USA: and the lift lever had popped through the tarp. I figured it was a B or C series something.
This past Wednesday, I past it again, and for the first time in six years, the owner was out mowing his grass (with a push mower).
I stopped. Asked if I could see the Horse. He said yes. I asked if it was for sale. He said yes. I said how much. He said make me an offer. I said $100. He said no. We compromised at $150.00
At this time his wife walked up and said, "if you are going to take the tractor, you've got to take the SNOW BLOWER too". I said how much. The owner started to say something and his wife said FREE.
Here is what I got:
It's a 1979 C-101 8 Speed with a deck and a snow blower.
Here's the bad news:
The tires are shot
The right tie-rod is broken
The sheet metal is bent and some rust-through
The wiring is burned
The transmission has oil coming out of every seal.
The engine blower housing is rusted through at the bottom and sides
The steering wheel is shot
The deck has a lot of rust-through
The snow blowers has rust-through and looks pretty tired
Here's the good news:
The dash panel is restorable
Okay, I was only looking for an engine to go on my Johnny Cash tractor.
Here's the news on the engine:
It's a K241AS
It turned easily by hand
There is no visible signs of oil leaks or head gasket leaks
Here's the better news
The starter motor works
Compression is 92
I've got spark :wh:
I did a simple wire-around to see if it would start and...
With starter fluid it runs. The muffler is good. There are no knocks and no smoke. Of course it's only running on starter fluid.
Can't keep it running though. Diagnosed that as a bad fuel pump. Got nothing coming out when I turn over the engine. Took it apart and found lots-o-crap on the inside.
But the good news is that I got a decent 10HP engine for $150.00.
Now I need to find a good fuel pump, and a good engine blower housing.
Bob
rickv1957
Good find there Bob,good price!before you know it you will have 50 :D ,Rick
JimD
Let's see, a good engine for $150., and lots of spare parts for use elsewhere, or to recoup some of the investment, sounds good to me! :D
rmaynard
Good find there Bob,good price!before you know it you will have 50 :USA: ,Rick
Not if my loving wife has anything to do with. She is at work and is not even aware that this one followed me home. :D
Bob
KC9KAS
Good haul....don't let her know you have a "new" tractor....just say, "Oh that thing, it has been around here for a long time!"
KeithB
good haul :D
bell
Did I hear someone mention "Johnny Cash tractor"?
Sorry, that name has already been used... :D:USA:
bell
Just kidding, of course... :USA:
I would rig up a fuel tank mounted higher than the carburetor and bypass the fuel pump... Maybe strap it to the hood? Then, you could drive it around and check out the transmission and everything else... Looks like a good parts donor! :D
scifi4all
Bob,
Glad to hear you got an engine for your tractor! :D
Irv
Bob, I just went thru kinda the same thing with an electro 12 that had sat for a long time. Fuel pump wouldn't pump til I got all the air out of the (new) gas line and of course I had to take the carb apart and clean it up.
VinsRJ
Were's the pics of the snowblower? We really want to see that, not some stink'n C-series :D
Nice Pick!
rmaynard
Sorry. Will call it Johnny Crash.
:wh:
Bob
rmaynard
Nice Pick!
Here 'tis
Bob
rustyoldjunk
i have had to prime the fuel pump on some tractors that have sit for a long time to get them to pump.
rmaynard
Took this one apart to find that it had water sitting in it for years. Aluminum is eaten away at the valve seats and it cannot be repaired.
Guess I am in the market for a new or good used one.
Bob
Doubletrouble
Nice parts tractor. I'd say you did ok. You have the motor you were looking for and spare parts to boot. :D
