horsefeathers 15 #1 Posted May 4, 2010 Transmisssion submission, guys my 854 trans axle wouln't shift in any gear has been sittin' all winter. not broken just sittin'. Electrolsis on shafts, rust or arthritis? This has happend before but I was able to get it workin' by rollin' 'n rockin' but wouln't budge now! Was told to change oil, will that work or do I have to rip' er out and tear'er down? Want to get the "Kriminal" back in to society! HORSEFEATHERS! Share this post Link to post Share on other sites
Jim_M 179 #2 Posted May 4, 2010 Drain it, fill it with a 50/50 mix of ATF and diesel fuel. Try to rock it loose after a day or two. After it breaks loose, fill it with gear oil and you're done. I'm betting you've never checked or changed the gear oil and it's full of water, The first time it stuck on you should have given you a clue that something was wrong. Share this post Link to post Share on other sites
VinsRJ 723 #3 Posted May 4, 2010 Drain it, fill it with a 50/50 mix of ATF and diesel fuel. Try to rock it loose after a day or two. After it breaks loose, fill it with gear oil and you're done. I'm betting you've never checked or changed the gear oil and it's full of water, The first time it stuck on you should have given you a clue that something was wrong. +2, Agree with this. Share this post Link to post Share on other sites
Duff 206 #4 Posted May 4, 2010 Much as you'd like to get the beast back on the road quickly, I strongly urge you to tear that tranny down and clean out the innards properly. My guess is that if it's been locking up like you describe and is really stuck this time, the problem inside is only getting worse. Might be worth it to disembowel it now while everything is still semi-salvagable rather than have a part or piece break off and tear up the whole tranny. JMHO..... Duff :USA: Share this post Link to post Share on other sites
rickv1957 73 #5 Posted May 4, 2010 Wheel horse trans can take lots of abuse but rust is the worst,Rick Share this post Link to post Share on other sites
horsefeathers 15 #6 Posted May 6, 2010 Kriminals owner is guilty as charged! 845 has been just sittin' past two years. The ol' boy has done hard time. And the warrden has been dishin' out punnishment! Duff yer right I think it needs taken down, but for now I like the quick fix, deisel fuel 'n ATF that'll loosen 'er up and may help when I break 'er down! This jailbird atin't goina' see freedom for awile! Thanks for the wake up call guys. HORSEFEATHERS! Share this post Link to post Share on other sites
