roelwelters
C-125 Gear problems
roelwelters
I have a c-125 and it is getting very hard to get it in to gear.
It started with only the reverse, but now all gears have problems.
It
KC9KAS
Is it hard to shift when the engine is running, AND when the engine is off?
If only when engine is running, maybe the clutch pedal is not letting the belt pulley to disengage enough for a smooth shift.
Sounds like a good idea to drain, flush and refill the transmission oil.
rickv1957
Hello and :D Rick
roelwelters
Yes it shifts bad without the engine running.
I already drained it, but i
pfrederi
Remove the gear shift lever. Is the ball on the end worn flat on the sides???
Under the rubber shift boot you will find an allen head set screw pointing forward, should have a lock nut on it. Remove set screw and lock nut... the shifter will lift out.
Also look at the set screw it is what is called here a dog point set screw (has a reduced size unthreaded tip portion. Is it worn ??
piecrazy4
:D welcome to red square !
