malibumike388
new horse
malibumike388
Photo-0008.jpgmy new wheel horse it is a 1970 gt 14. gonna repaint it.just got to do alittle tinkering with the carb and check trnas fluid.because it'll move when i have it on jack stands but not when its not.it sounds like a sucking sound. but the lift works.
whfan74
Nice, straight looking tractor! Congrats on your new toy!
malibumike388
thanks.i hope the trans isnt shot. where these painted with the white grill from the factory or did someone paint it this way?
whfan74
Someone painted it that way............
Good luck with the tranny!
rickv1957
Nice tractor,make sure the tow valve is closed, :D Rick
KeithB
nice one, enjoy :D
Ole MN
Nice looking 14, :D
your going to enjoy it they are a great tractor
Ole MN
Oh and :D
malibumike388
i looked at the sticker under the seat and it said to have the valve facing forward and thats how it is. btw i saved this from the scrap yard
HankB
Nice save! :D and good luck getting the trans sorted.
malibumike388
well i found out its out of trans fluid.what can i use for it cant find type a trans fluid.
HankB
There has been considerable discussion of this lately. My chart shows that the GT-14 used a Sundstrand transmission. Older ones used Type-A ATF and later ones apparently switch to 10W-30 or 10W-40 engine oil. There is apparently also documentation stating that the older ones could be switched to engine oil if all of the old ATF was removed (by serial changes of oil.)
The simplest solution is to see what's in it now and match that. I would guess it has ATF as I think that's what those came with from the factory. Type-A may no longer be available but I seem to recall hearing you can use Dexron.
Edit: Here's the other thread: http://www.wheelhorseforum.com/index.php?...17912&hl=dexron
papaglide
The service updates at my local ex-wheel horse dealer stated that Dexron II or Mercon ATF is the now recommended tranny fluid for a model GT 14.
malibumike388
well i started to tare it apart.just gonna repaint and put in new bolts.just a quick paint job.if i had the money i would've had the pieces sandblasted maby next time. its gonna be krylon cherry red i masked off all the decals they wore in good shape.i just hope its not a waste of time. because i dont know if the trans is shot.i will take pics when its done. i was thinking about putting a stack on it. and what do u think it will be worth when its done? thanks,mike
malibumike388
Raider12
Your at least making some progress. Looking good so far.
MRM
Looks good, Wish i had a GT14
malibumike388
got the back fenders on and seat took the tape off the decals on the hood
Lawn Ranger kid
Looks great. :D
Josh
rickv1957
Tractor is looking great!,Rick
malibumike388
getting ready to do some final touch up on the paint and gonna repaint the wheels then gonna rebuild or refresh the engine.
