1961551 2 #1 Posted April 29, 2010 hi, i have a 1054 tractor that i want to use for a tiller. the 3 speed wont cut it . i have to transplant a low range tranny. anyway, my question is, what do i have here? it has long axles. 1 1/8 in diameter.its odd, but is this desirable? im looking for options. can i use 8 speed cases and internals and use these bigger axles and diff? if not, i plan to use the short 8 speed tranny with offset ford car rims and 30x9.50x15 mud grip tires. thank you. jimmy Share this post Link to post Share on other sites
pfrederi 18,279 #2 Posted April 29, 2010 The tranny will not care what length axles you use Share this post Link to post Share on other sites
1961551 2 #3 Posted May 1, 2010 ok. well, all i have are the low range trannys that are 1 inch axles. dont have any 1 1/8 axle 8 speeds. thanks. jimmy Share this post Link to post Share on other sites
Kelly 1,030 #4 Posted May 1, 2010 I don't know all the details but the axles from your trans will not fit a 8 speed with out machine work, and the bolt pattern to mount the trans to the frame is different, you will have to drill the frame, it can be done just not abolt in, a menber here did it. Rollerman I belive is the one you want to ask. Share this post Link to post Share on other sites
clintonnut 126 #5 Posted May 1, 2010 Don't use the 1054 differential. You can use the 1054 axles if you grind a groove for the c clip on the differential end of the axle. I just did it today for my 953. Used 953 axles with an 8 pinion rear. Done this 2 times now. I'm not sure if the standard 8 spd axles provide enough length for the rims used on your tractor. You'll have to experiment. Good luck finding a cheap 8spd! Charlie Share this post Link to post Share on other sites
linen beige 14 #6 Posted May 1, 2010 On another note, the rear mount tillers won't hook up to a 1054. Share this post Link to post Share on other sites
