rustanddustinc
1972 WH Commando 36" RD deck bad center spindle be
rustanddustinc
Hi,
I am brand new to your site. I just purchased a 72 WH Commando 800 w/36" rear discharge deck 5-0620. Ive always wanted a WH and finally got a chance to own one.
The center spindle bearing/s have gone out. I was wondering if someone could point me in the proper direction for bearings?
Thanks alot for your help!
jason
mavfreak
I Love my commando!
:omg:
Someone here I'm sure has the info you need :D
Raider12
You can go to the Toro web site https://www.shoptoro.com/Comergent/en/US/ad...&isManuals=true
But I looked this up and found no parts available for your deck. If your interested, I have a deck I can sell the parts off of.
You may be able to take the spindle apart and buy just the bearings at a local bearing distributor as well?
rickv1957
Hello and :omg: Rick
WH854
You can go here and put your tractor model# I think it is(1-0110)
it will tell you what is available. Look under accessories and attachments.
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Hope this will help you out :omg:
Chas
PS :D
mavfreak
raider 12 is right you can take it apart and buy bearings. as long as shaft and housing are ok its fixable
Raider12
The Toro site is showing this part as obsolete. The Toro site also shows it as an assembly to and not a break down of the bearings and shaft etc. But that doesn't mean there are no part available. There are other sources for these parts, but unfortunitly I am at my office and I do not have those web sites saved on this PC. Someone else will chime in later this evening and add to this to help you further with another location of parts.
:omg:
TT
That should be the predecessor to the short iron housing with the "water pump-style" 103119 bearing assembly.
I can't remember exactly, but I think they are serviceable just like the newer version, but I would have to see a picture.
Here's a LINK to an eBay listing for the NLA 103119 bearing ass'y.
