abrown0920 0 #1 Posted April 27, 2010 I am working on a full restore for my 702 and I believe I have a small leak issue at the brake seal. I am pretty sure that the napa part numbers for these seals were posted last year but I can't find them. Is this most likely just a seal leak and easy fix or should I be concerned about a bigger issue. It drove and shifted fine before the tear down. Thanks for any help! Share this post Link to post Share on other sites
rickv1957 73 #2 Posted April 27, 2010 Based on what you have said a seal should take care of your leak,trans looks pretty clean in picture,Rick Share this post Link to post Share on other sites
rmaynard 15,887 #3 Posted April 28, 2010 Check out this post: http://www.wheelhorseforum.com/index.php?...c=17168&hl=5025 It might help you. You should have a 5025 tranny. Both of my 1977 8-speeds had leaks at the brake seal. Seems to be a weak spot on all of these units. Bob Share this post Link to post Share on other sites
Horse'n Around 22 #4 Posted April 28, 2010 Can that seal be replaced with the trans intact or does it require splitting the cases? John Share this post Link to post Share on other sites
rmaynard 15,887 #5 Posted April 28, 2010 I'm sure someone will chime in with a definitive answer on that, but I would think that it could be replaced without opening the case. Bob Share this post Link to post Share on other sites
rickv1957 73 #6 Posted April 28, 2010 You can replace seal with trans intact,just use a pick and carefully pry old seal out,Rick Share this post Link to post Share on other sites
Horse'n Around 22 #7 Posted April 28, 2010 You can replace seal with trans intact,just use a pick and carefully pry old seal out,Rick Thanks you for the answer. That seal looks so thin that from the picture I couldnt tell if it was externally accessable or not. Its good to know that it is for future reference. Thanks again, John Share this post Link to post Share on other sites
stevasaurus 23,036 #8 Posted April 28, 2010 the seal you need is Toro or Wheel Horse part #1232...it is available from your Toro dealer. You probably can match it up at the auto shop, but I did not . The seal is inexpensive compared to some of the bearings in that trans. I would change the fluid also, just to see. Piece of mind. :omg: Share this post Link to post Share on other sites
pfrederi 18,279 #9 Posted April 28, 2010 Toro 1232 is CR 9815 for the 1" brake shafts. Share this post Link to post Share on other sites
