kpthorsefan
Covers are off, C141.
Save Old Iron
Painting a hot surface the color Black actually has an advantage, The black increases the "emissivity' - google it - of the metal surface.
A black surface emits additional heat from the ability to process the heat as increased emissions of long wave infra-red radiation.
A black surface is considered the standard of emissivity that all other colors are judged against i.e. all colors other than black don't dissipate as much heat thru radiation.
kpthorsefan
Just a quick update put a few more bits on the engine, the head is just resting on the top, does any one know of a good way of cleaning and polishing the head fins? dont really want to paint it.
rickv1957
A dremel tool,some time,you can polish it,Rick
kpthorsefan
well i have done a little bit more, i had the head blasted with glass beads at a local factory just waiting now for the new HT/ head bolts to come. Also i have bought a metal lathe which i have been trying out, not used one for over 39 years when i was at school, I have changed the front axles and tyres a bit :) . Here are a few pics.
btrrg1969
That sucker looks cherry , very sharp , love the tires and the front hub , where did you get hubs like that ? :)
btrrg1969
also the exhuast is killer :)
JimD
Your tractor is beautiful. Very nicely done. It looks like the new spindles give it a wider stance. I like that a lot. Are you going to put the engine shroud on to direct the airflow up to the cylinder and head fins? :)
kpthorsefan
Hi brandon, the hubs and wheels where of an old 6x4 trailer i had, the stub axles i had to turn down on the lathe and bore out a 3/4" hole so it went over the tractor spindle which i had to shorten a bit.
kpthorsefan
Hi jim, i have put a picture on with the shroud, i cant put the tin work on yet, waiting for the new head bolts, and some cable sheath for the stator cables which were all cracked and split.
kpthorsefan
Brrly1
Hello, that is one good looking tractor. I bet you just can't wait to hear that motor come to life. Hoping to see some pictures of you out pushing some snow this winter. Like I said the tractor looks fantastic. Keep up the Good work. See Ya, Bye
Burly :)
:USA:
stevasaurus
Beautiful tractor. :) I too am liking those front hubs, it is a sharp look. :USA:
SAM58
WOW :)
GREAT JOB!!
:USA:
landsurveyor
Hi Kevin,
Your tractor is coming along very well!!
I have the same tyres on the front of mine, they do look good.
Dont suppose you would want to make one of those exhausts would you??? I cant find one like it anywhere, and my welding skills arent up to making one!
Keep up the good work.
Simon.
Horse'n Around
Your doing an incredible job on it! The changes that youve made are very well done and thought out. Its really something to be proud of!!
John
bo dawg
That is one sharp tractor :) I would hate to see it get dirty :USA:
massey
Super job, I like it all, especially the tire choice.
rickv1957
Nice work,tractor looks super!!! :) Rick
kpthorsefan
Burly :wh:
Hi burly, I'm afraid there will be no snow pushing or work for it :USA: i am hoping to take it to a few shows in the future, i managed to fit the head on today, will post a picture later. many thanks for you comments, all the best :)
kpthorsefan
Here is a picture of the head fitted..
kpthorsefan
Not far to go now, done a little bit more its just odds and ends to do, then its the electrics. :)
kpthorsefan
Hi all, I bought some tail lights off ebay from the US :) , they came today and it said they were new and they fitted a GT14, they looked the same as the lights for my C-141, so i took a chance and bought them. And they fitted a treat :USA:. here is a pic of them fitted but not wired up as i am still doing the electrics.
stoneman
Outstanding job on that tractor Kevin! Outstanding.
racinfool40
:USA: :wh: Outstanding- One sharp machine and you've done a great job :)
fishy1179
looks good.
